Virgin Media
Wireless home broadband with the Virgin N Router
Fast speeds, fantastic range
Our router uses the latest wireless technology (called wireless ‘N’) to send a strong and reliable signal throughout your entire home to all your gadgets and gizmos at the same time. So you get zippy broadband speeds and the freedom of connecting wirelessly!
Our wireless 'N' router is included with all our National broadband packages.
The latest wireless encryption technology
To make sure you stay safe online, our router features the latest secure encryption technology to protect you from any unwanted intruders. Just set up a password and away you go.
Find out more about internet security
Free technical support
If you need a hand with your broadband, just call free from a Virgin phone line for on the spot help.
Under the hood
Package contents
  • N150 wireless DSL modem router
  • Ethernet cable
  • Phone cable and ADSL2+ filter
  • Power adapter
Standards and performance
  • IEEE™ 802.11 b/g 2.4 GHz with ‘N’ features
  • Four fast ethernet ports
Physical specifications
  • Dimensions: 177.5 x 130 x 31mm (7 x 5.1 x 1.22in)
  • Weight: 0.265kg (0.584lb)
Security
  • Wi-fi protected access™ (WPA/WPA2–PSK) and WEP
  • Intrusion detection and prevention (IDS)
  • Denial-of-service (DoS) attack prevention
Advanced features
  • Power and wi-fi on/off buttons
  • Supports push-to-connect for compatible wireless devices
What services can I get?
Please enter a valid postcode
Build your own bundle
Broadband, TV and phone. Create your perfect mix.
Build your bundle
back to top
